12-22-2015 |
5.00 |
Rudder cable and elevator pushrod |
Installed rudder cable in fore fuselage. Drilled 1/8” pilot hole in SNX C03-05 and standed paint on SNX C03-06 to ensure easy and smooth fit. Will help with push rod assembly. Installed pushrod and rudder cables. Note: If you take the easy way and slide the two pushrod pieces together, then drill the holes for the AN3-12A bolts you can’t pull them back apart! I got it to work but wish I would have drilled small pilot holes and then taken apart, then up-drilled when unassembled. |
