Date:    11-11-2009
Number of Hours:    1.00
Brief Description:    Canopy halves drilled
Seems like it's been a long haul since I started this canopy. The frame and hinge design requires a bunch of fiddling to get right. Once you think you've got everything perfect, it seems the shape changes when you put it back on. As you rivet portions, they change again. At some point, it seems like the only thing to do is move on.
