10-2-2007 |
2.00 |
Final Assembly of Right Wing Begun |
I started final assembly of the right wing this afternoon after work. I installed the right bellcrank assembly and torqued the bolts to their final specs. I also leveled the wing skeleton again and started riveting the skeleton together. I got as far as riveting all of the rear ribs to the main spar. Wow. Afer all of this time of preparing, sanding, painting, fabricating, measuring... it's finally going together in final assembly. What a huge accomplishment. |
