Spent a little time taking care of more wing details today despite a heat index of 109 degrees in the shop. That does it, I'm definitely installing an air conditioner in there. I'm going to cut a hole in the door and put a window-unit in there. I guess it'll be a door-unit then, huh? I put conduit stand-offs on all ribs except 2 an 3. They're so close together, I don't think it's worth the added weight. I also finished up bending 4-foot sections of wing tip angle - one at 45 degrees, the other at 135 degrees. Piece of cake. I may work on that air conditioner tonight when it cools off...
