Finally finished up the center spar this morning. There were a lot of little side projects to finish up before I could do the final assembly, but after a while, there was nothing left to do except bolt it together and rivet the top flange over. The bolts fit nice and tight. They actually had to be hand-pressed into place or driven lightly with a soft-face hammer to get them in place. That's pretty much the fit I was looking for. I torqued the nuts to 65 in-lbs per the FAA manual. Since I had been so meticulous about dimensions, everything fit together beautifully. The top flange was blind-riveted into place with A5 rivets. Good solid structure - it feels very solid and secure, and a lot heavier than any other assembly I've built thus far for this project. Now on to the outboard spars.
