I've spent a day or two fabricating and attaching all of the standard "L" angle brackets for the passenger side seat, and completing the passenger side arm rest. This is slow and a bit tedious, but very important stuff. What takes so much time is that all of the angles have to be measured, then cut with angles ends, then drilled, etc. It's also kinda hard to get into where you're working. I've used my tight-fit drill kit a lot in the last day or two. I'm expecting the pilot's side to go a little quicker because I'm planning to use the angles I've already completed as patterns for the remaining side. That's the plan any way - we'll see how it works out.
