I've begun preparations for final assembly of the fuselage bottom. I've been priming all of the mating parts and small stuff, as well as drilling out holes to their proper size and deburring. I switched to the grey NAPA 7220 primer for the fuselage. I think it'll look better once I get to some of the more visible parts. It seems to cover a little better too. All I have left to drill and prime are the longeron splice parts on the right side, the front right longeron, and the bottom skin. After that it's assembly time. I expect that the bottom will be together in a couple of days.
