Date:    2-5-2012
Number of Hours:    3.20
Brief Description:    Wing Assembly Work
I started putting some of the cleaned up wing components back today. The first two inboard compression struts are back on the right wing along with the fuel tank bay's drag/anti-drag wires. Fitting those compression stryts back into place over the top of the wire attach fittings is an exercise in patience. It takes way too much time to get all the components lined up for the attach bolts to fit through the spars. Two out of three of the leading edge skins are removed from the right wing.
