Today's session was a group of mini projects, with me going back and installing correct hardware in a few places, finishing up other areas I had started in, etc. I finished up mounting the cabane strut fairings with their new holes drilled and finished. Also, I replaced the bolts attaching the wings struts to the fuselage with ones of the correct length and got them tightened and pinned. Next, I got the upper gear leg fairings into place. With the correct hose clamps in hand, my main fuel pick-up lines are now hooked up. Lastly, I went back to work on my wing root fairings, starting on the bottom pieces. That's pretty slow going but I think it will work out nicely.
