Date:    6-16-2014
Number of Hours:    2.50
Brief Description:    Interior and Firewall Work
There were a couple of areas in the rear of the cabin that needed better trim pieces made, so I took care of that today. I also started tackling the firewall puzzle. I installed the new Airtex firewall pad and then got to work cutting the holes for things that need to pass through the firewall. Between engine mount bolts, fuel lines, cbin heat inlets, wiring, control cables, etc. there are plenty of holes to cut. Also, I retrieved the pieces that form the cabin heat inlet and started to work on their assembly.
