Date:    7-3-2014
Number of Hours:    6.00
Brief Description:    Door Seal Work
I worked on what passes for a door seal on the fuselage. Some of the seal pieces were too worn out to re-use so I had to fabricate several pieces of strip material. I tried to incorporate the rubber door seal material that some planes have, but had real door fit problems and decided it was not worth it. I may still try to find a smaller version of the "P" seal material and fit it later. Otherwise, the fit is complete.
