Date:    3-3-2013
Number of Hours:    3.00
Brief Description:    Cowling Work
First time back in the hangar in a while. With all the new cowl pieces fitted, I went to work on the lower cowl. I removed the small cowl scoop and the large air scoop from the old bottom piece and started fitting the pieces to the new cowl. All of the baffling for the carb air box will be new. To see if the center hole in the new bottom was aligned, I re-installed the carb air box and the Brackett air filter frame. The fit was great. Next session, I'll finish up the fitting of the scoops.
