Date:    12-19-2011
Number of Hours:    2.00
Brief Description:    Fuselage details
Worked on some details in the fuselage. I made and installed some frames for different plates that must be mounted in the interior such as trim position indicator and fuel valves. Also, I installed the last of the drain hole grommets on the control surfaces. I started getting the fabric fitted to my last gear leg assembly. Hopefully, I can get that covering wrapped up next session, and then all of my small pieces will have been finished.
