Date:    11-10-2011
Number of Hours:    3.00
Brief Description:    Finishing Fuselage Tapes
Installed the last of the fuselage reinforcing tapes, checked all my work, then started the clean up prior to starting with the EkoFil. I decided to start filling the fabric with the bottom side, so I checked all that surface for anything that need removal/cleaning, Wiped the surface down with cleaner, and got started with the filling. I did the first half of the cross coat and let will let it dry before coming back and doing the other half.
