11-3-2011 |
3.20 |
Tape and Inspection Frame Work |
I worked on the horizontal stab inspection frames on the left side. Glued the frames in place, let that dry, then cut the fabric on the inside of the frames to glue back onto the frame itself. When that was dry, I glued the doily onto the two inspection areas. |
