Installed the battery compartment door on the fuselage right side. Also, started on the left side fuselage fabric, the last major fabric piece to be installed. I started using a technique recommended by a friend involving putting glue on the fabric edge and allowing it to dry before making the pinking cut. The result is a very crisp adge with no fraying at all. Works great. The overlap seam on the bottom edge and the top edge on the stringer centerline are now glued down and are set & ready for shrinking. Next session, I'll finish up the forward and trailing edges. Then it's time to shrink.
