1-18-2015 |
1.50 |
Longer Engine Run |
I corrected a few things with the engine today and ran it for its first real session. I got the oil temperature up to around 120-130F while taxiing around. I got my brakes burned in a little bit and discovered a small issue with my tailwheel steering. I got that assembly lubricated a bit better and all works great now. My idle is much closer to where it needs to be. I figure I'm just starting the debugging process. |
