Date:    3-1-2007
Number of Hours:    4.00
Brief Description:    HS Rework
Had to rework part of the HS because of 2 mistakes. I screwed up both HS 404 ribs. The first mistake was making a cut line then cutting out the wrong piece of material. The second was taking too much material away in the area that needs trimmed to make the HS 404 fit between HS 710 and HS 714.
