Fabaricating the fuel tank vent lines was fairly straight forward. The vent lines are hidden are hidden inside the gear towers so they are not see but getting them bent correctly and getting them into the gear tower was a challeng. When they were done I move to the fuel filter to fuel pump line. The line runs from the filter thru the gear tower and into the forward fuselage area next to the rudder pedlals. Bending this line is a real challenge because it has to be flared and installed before the final bend and flare on the other end. I am not happy with the way this turned out and may attempt it again when I finish the other fuel lines.
