Date:    11-24-2017
Number of Hours:    3.50
Brief Description:    Fabricate a mounting shelf for the GMU-11
I fabricated a small shelf in the aft portion of the fuselage for the GMU-11 Magnometer according to lthe instructions in the Garmin manual and some advice from Aerotronics. I used a small piece of aluminum sheet for a plate and some angle stock for supports. Drilled holes for #8 screws and deburred and primed all parts. I will need to order some stainless steel screws and mounting nuts for final assembly.
Before calling it a day I located and drilled a hole in lthe F-810 most aft bulkhead for the ELT antenna.
