4-19-2017 |
5.50 |
Seat floor and footwell assembly. |
Temporarily placed the front seat floor with screws and match drilled #19 the two holes common with the F805C seat floor support angle and the two F-805D brackets. Drilled #40 holes for mounting nutplates to both F805D brackets. Deburred the two holes and Machine countersink for flush rivets. Marked the center point of the bottom half of the front seatback hinge, located the hinge over the corresponding holes in the seat floor and match drilled #30. Assembled all parts for the left and right footwells. Drilled all 3/32 holes common between parts. Attached footwells to forwar seat floot and match drilled all holes in common. Disassembled and deburred all holes. |
