2-10-2016 |
3.50 |
Finishing the flap hinge, adding aileron stop. |
Today Parker and I riveted the left and right flap hinges into place on the wing trailing edge. We made a bushing out of delron rod and drilled a hole in the middle to slip the aileron attach bolt through. We removed 4 flap hinge loops and cut the hinge pin into two pieces. Now the pin is much easier to remove and can be secured in the middle of the flap. |
