Date:    4-28-2015
Number of Hours:    4.00
Brief Description:    Preparing the left elevator
Started the day by removing the clecos that hold the E-705 root rib to the E-702 elevator spar and then cleco and drilled the WD-605-1-L elevator horn to the elevator spar and root rib.
Cleco and final drilled the E-606 trim spar to the root rib.
Match drilled the left elevator skin to the understructure, and also drilled the elevator tip rivet holes #30 to accept the CS4-4 blind rivets when the time comes to rivet the fiberglass tip on.
Machine countersink the E-714 C/B lead weight to accept the dimples formed in the E-713 C/B skin.
Machine countersink for the E-705 root rib attach holes on the forward face of E-702 elevator spar.
Beveled the inboard and aft edges of the E-713 C/B weight skin where it overlaps the spar and rib flanges.
Finished deburring most of the left elevator understructure and scuffing with a scotchbrite pad before dimpling and adding primer.
