Date:    4-14-2015
Number of Hours:    6.00
Brief Description:    Preparing the elevator
Worked for about two hours before Parker arrived to help out. Scuffed the inner surface of the elevator skins and all the elevator stiffeners, and the trim reinforcement plate.
Washed all the stiffeners and trim reinforcement plate and elevator skins before applying primer.
Dimpled the left and right elevator skins.
Primered all parts.
Riveted the E-615PP trim reinforcement plate and all stiffeners to the left and right elevator skin.
Cleco and match drilled the spar reinforcement plates and the inboard and outboard hinge doublers to the left and right elevator spars.
Prepared the E-703 end rib and E-704 counterbalance rib by fluting and edge finishing on the scotchbrite wheel.
