2-6-2015 |
3.00 |
Riveting left HS together |
Today I continued with the left HS construction by riveting the left outboard rib HS-706 to the forward spar HS-702 where you can see the two gold clecos. With all the ribs in position in the left HS, now it's time to start riveting everyting together. This started with the aft middle rib riveted to the skin (image 2) and then continued with the forward spar riveted to the skin (image 3). |
