1-14-2015 |
0.50 |
Attaching left inboard ribs to the forward spar. |
As seen in the first image, the left side forward inboard rib HS-0006 has been riveted into place through the forwar spar assembly and through the aft inboard rib HS-0005 which you can see in image #2. I couldn't reach the rivets with a pneumatic squeezer so these had to be done with the hand squeezer. |
