10-31-2014 |
3.00 |
Match drill stiffeners, rear spar, hinge brackets |
Cleco'd then match drilled the HS reinforcement bars to the HS rear spar. Cleco'd and match drilled the elevator hinge bracket to the HS rear spar assembly. Prepared the VA-146 bearing by match drilling with supporting hinge brackets. Deburred all parts. Primed theVA-146 bearing and viveted in place between the two hinge brackets. |
