10-6-2013 |
1.00 |
Installed upper plug wire grommets |
The upper plug wires need to enter through the rear baffles. I purchased these nifty two-piece grommets from Aircraft spruce (darn little buggers are $20 a pop!). I used the unibit to drill a couple (overlapping) 7/8" holes and then drilled the bolt holes above and below that secure it in place. |
