8-30-2012 |
4.00 |
Misc. Wing Work |
I finished dimpling the two large bottom wing skins and removed my flaps fro the wing for temp storage. I was reminded by the bottom skins that the flapshave to be removed for the bottom skin slot to slide over the flap bracket. I also made the same modifications to the pushrod hole in the rear spar of the right wing. I'll add some pictures of this later but I did get the Safeair pitot tube support mast installed in the bottom skin of the left wing. This required cutting a hole in the wing skin much like the leading edge lights. This will house a dynon heated pitot tube. The mast is ready and will be riveted in place along with the bottom skins. |
