Date:    3-31-2012
Number of Hours:    0.50
Brief Description:    Hinge Bearing
Clecod, match driller, deburred and riveted the rear spar hinge dearing assembly. I started off using my rivet gun, which was tough on this small part.... then realized I could probably use my squeezer, so i finished it off with that...
This will be installed to the rear spar of the horiz. stab once it is complete.
