Date:    1-5-2012
Number of Hours:    2.00
Brief Description:    Forward/upper skin
After getting the instrument panel located I moved on to fitting and drilling the skin. I layed out the rivet pattern on the underlying structure so I can back drilll everything once the skin is where it needs to be. I drilled about 6 holes down the center and called it a day (night).
