Date:    8-21-2012
Number of Hours:    16.00
Brief Description:    Mounting tail surfaces
Over the past couple of weeks I have been working on mounting the tail surfaces. I have been trying to get out there early and work a few hours at a time before it gets too hot. I have managed to get the horizontal and vertical stabilizers located and drilled. I have also mounted the rudder and ran the control cables which will be explained in the next post. I have had to add a few shims here and there but I talked to Vans and they said it was normal to make everything fit right.
