7-18-2012 |
3.00 |
Throttle, Mixture, Carb heat controls |
I spent a few hours this morning installing the control cables for the engine throttle, mixture, and carb heat. I cut and installed the scat tubing that runs from the naca scoops to the eyeball vents. All of this is temporary and will need to be pulled back out of the plane to allow for painting of the instrument and sub panels. |
