Date:    1-25-2014
Number of Hours:    1.50
Brief Description:    Aierlon Brackets and bellcrank
Installed Bellcrank and mounts into the right wing today. Torqued bolts as per section 5 on bolt torque specs. In this case it worked out to 20 lbs foot torque. went well hopefully tommorrow I will begin the left one as well then onto the installation of the aierlons and the pushrods.
