12-2-2012 |
4.00 |
Fit the drain and fill flanges and dimple T skin |
I fit the filling cap flange and drilled it and then did the same for the drain hole. Dimpling followed for about two hours .. dimpling is not the best part of building. Found the tank baffles previously made and then took my die grinder and bunished the matting edges of both the flange and the tank so that the pro seal will hook onto the edges provided by doing so. Well next step is the dredded Pro seal work, here is hoping all goes well there. |
