6-5-2012 |
2.00 |
Continuing the install to left wing of the Z angle |
Completed the install of the Z angles to the spar and then attached the 702 baffle of the tank All seems well so far, when i read the manual it talked of leaving the seventh Z angle blank and then back drilling the angle to the spar. I could not seem to find out which Zangle so I chose the outboard angle it appears to be the right one. Baffle is clecoed in place and ready for the next step. |
