3-4-2012 |
4.00 |
Reinstalled wing to upright holders and took out r |
Removed the rib W712 - r somehow got the wrong 712 in there it removed easily though and I really am getting better at removing the rivets. The correct way of taking the head off first then the punch is used to push the shaft out through the hole works the best. The trick is to shave a bit off a 1/8 punch so it is smaller than the 1/8 hole, screws up the punch but we have to make sacrifices dont we? The rib is in and the wing is mounted again in the jig, I will try to rivet in the jig however, it didn,t work too good the last time so we will see. All in all a good day in the shop and the wing looks great, I am going to have an airplane I think. No pics |
