Date:    1-22-2012
Number of Hours:    2.00
Riveted the rib to the bottom of the Triim tab and then rebent the tabs on the inboard and outboard ends this is as far as I can go without an inspection so the elevator is complete for me now until the inspection then in need to complete riveting and close up the structures. Also I will need to install the hinge and roll the edges for completion. All in all the empannage has been good and will likely get easier now that I am out of the modified RV 6/ 7 kit and onto the RV 7 which should have an easier build to it. This is getting to be fun!!!
