Date:    5-23-2011
Number of Hours:    5.50
Brief Description:    Left Hand Stiffeners
Worked on the left hand elevator today and match drilled the stiffeners to the skin of the left elevator. Took a long time to do as the overlap did not present a clear picture but in the end i understood it and it worked out fine.
Also dimpled the stiffeners after deburring in preparation of riveting to the skins once they are dimpled.
Looking good it feels good to see it slowly advancing, at this point i should see the benefit of the new RV 7 kit as this is the last of the modified RV 6 tail.
Deburred and dimpled then riveted the lower stiffeners onto the left hand skin, went well
