10-30-2010 |
4.50 |
Installing stiffeners to the Rudder right hand sid |
Match drilled and dimpled the rudder skin and back riveted the skin onto the stiffeners. Worked good minor error made in dimpling when i stamped a hole were one should not be. The rivet went into the correct hole and some cosmetic prob but no structural problems. The error should come out with a little bondo and paint. |
