Date:    5-8-2011
Number of Hours:    1.50
Brief Description:    Wire Looms
Measured, cut, drilled the sparkplug wire loom supports. Once satisfied I installed the wire looms. It helps make the engine look clean and neat! I discovered that the loom bracket washer/spacer are too small for the top cover SS pan head bolts.
