Date:    3-15-2008
Number of Hours:    0.50
Brief Description:    Corroded Cylinder Stud Removal cont.
I bought at ACE hardware a couple of Grade 8 nuts to remove the final 3 upper studs needing replacement. I easily removed 2 of them. The last stud proved to be a challenge so Im going to use the candle wax, double nut, heated case and cheater bar method to remove the stud. This still did not remove the stud!
