11-1-2011 |
1.25 |
Trimmed & Sanded Flap Skins |
One of the flap skins was slightly damaged so I selected left/right flap skin based on cutting off the damaged portion as scrap. After confirmation w/ Kerry from Sonex, that the upper & lower Inboard edge dimensions differ, I needed to trim the upper inboard flap surface as the length as measured from the outboard edge is slightly shorter than the lower inboard edge. I had initally cut them to the same length. Luckily for me the upper edge was shorter than the inital cut! After the edge was trimmed on each flap skin I resmoothed/resanded them. Next, I measured, cut and sanded the flap drive cut-out on both flap skins |
