3-3-2008 |
4.50 |
Aileron Support Frame, Inboard Flap Arm |
Finished welding on the #2 end of the second aileron support frame and cut pulley support to correct length. Had previously bent the inboard flap lever. Cut lever to correct shape. Cut, shaped and welded doubler to tip and welded arm to 7/8" tube. |
