Date:    2-19-2008
Number of Hours:    5.50
Brief Description:    Aileron Support Frame #2 - Bellcrank began
Welded bellcrank support to main frame. Shaped and welded 3/8" bracing tube for bellcrank support. Made, welded then reamed to 1/4" ID the 7/16" support for the cable pulley. Started to weld #2 end to support. Ran out of acetylene.
Machined main bearing body for bellcrank and cut and fit bearing support tube.
