Date:    5-4-2010
Number of Hours:    1.00
Brief Description:    Trial Fit Gas Tank / Felt Lining
Installed the fuel tank in order to establish a final location for the fuel line adel clamp I want to install to help keep things stable.
Noted that I'll need to trim off about 3/16" from the end of the fuel line where it goes into the fuel tank shutoff valve since it was extremely tight.
Checked fit of the fuel tank straps and other under-tank items for proper alignment and to make sure nothing was rubbing on the tank (I've installed a lot since I first installed the tank).
Removed the tank and the fuel line. Cut felt to line the top of the fuel tank. Still need to procure thinner felt to line the tank straps and glue everything into place.
