Date:    11-15-2009
Number of Hours:    1.00
Brief Description:    Flip Fuse / Install Seat
Not much done today / this weekend. Went to Kansas to watch KSU lose to Missouri (rats), and had some folks come over to see a Sonex project in action (glad you made it, Rey & Patricia!).
Finally flipped the fuselage right-side up; now I can finish the fwd fuselage - glareshield, fuel tank, rudder pedals, other controls, engine, and avionics. Almost done (with only another 80% to go...).
Fabricated seat pan hinge pins. Cut to length, bent to 90 deg at the end. This secured the seat pan to the lower part of the fwd fuselage. Still have to position and drill the upper and forward hinge halves that will match those already on the seat pan.
