11-12-2009 |
2.00 |
Add Piano Hinge to Seat Sling Panel |
The seat pan was finished the other day, as was the initial locating of the center seat hinge section, which was only pilot drilled. Tonight, I up-drilled the center hinge section, and located, clamped, pilot drilled, up-drilled, deburred, and riveted the upper and forward seat hinge sections to the seat pan, which finished this subassembly. |
