Date:    3-3-2009
Number of Hours:    1.20
Brief Description:    Right Flap Detail Work
Started the right flap tonight.
Got out the parts, dug around for the flap drive plate, ribs, etc.
Marked out cut measurements on the right flap. Drilled 1/8" relief hole prior to cutting drive plate access hole.
Positioned, drilled, cleco'd and up-drilled SNX-W06-05R drive rib assembly.
