Date:    8-16-2008
Number of Hours:    2.30
Brief Description:    Spar Parts, Rear Spar Material
Continued with SNX-w08, Main Spars (L/R).
Installed 16 AN3-7As (8 each spar) on lower edge of inner spar as per plans.
Fabricated SNX-W10-06 tip attach angles (2). test fit to spar, drilled as per pilot holes in SNX-W10-07 (part of prebuilt spar), then riveted with CCP-42's.
Since I had to dig out the SNX-Z01-03 angle for the SNX-W10-06 attach angles, I went ahead and cut-to-length and width SNX-W13-05 L/R which are also made of the same stock. Then, since I was already deep into the raw stock, I also obtained the lengths of stock for the rear spars, SNX-Z01-02, and the 1/8" x 1/2" bar stock for SNX-W13-03 radius blocks.
Fabricated all 4 radius blocks by cutting to length and radiusing them to fit the pre-fab'd SNX-W13-02 (L/R) root rib attach brackets that are part of the machined angle components kit.
All that remains on the main spars is to torque all AN3 / AN4 hardware (still don't have a torque wrench!), and drill the 5 attachment / alignment holes to 1/4".
Have to trim the angles on SNX-W13-05 (L/R) and that page of the plans will be completed as well.
